sticking trans?
Old May 19, 2009 | 12:01 PM
Donny_D's Avatar
Donny_D
sticking trans?
yesterday i was coming onto I-15 didnt make it off the on ramp and struck got stuck in 3rd gear and stayed at 3,000 rpms and stayed there blowin smoke like i have never seen in 80E... i let my foot off the pedal and it shifted and stopped.
just went for a drive and it did the same thing same speed/rpms... did it again in 2nd at about 35mph stuck and smoked like crazy.
PS: i turned the tuner to stock and did the same test, did not stick or smoke at all.
thanks for the help in advance guys and gals!
Old May 19, 2009 | 12:49 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This is a strange one. Did you check to make sure the chip is still tight on the pins of the PCM? This may be a question for Jody.
Old May 19, 2009 | 03:09 PM
Donny_D's Avatar
Donny_D
checked the PCM and the back of the selector switch, both were good and tight, went for a drive and tested after tightening problem is still there.
oil level is good and trans fluid is at operating level on dip stick color is fine no burnt smell
Old May 19, 2009 | 03:56 PM
miller_feed
I would talk to Jody about this. He would have the most knowledge to help you. Good luck.
Old May 19, 2009 | 04:02 PM
Ponyboychris's Avatar
Ponyboychris
Only in the 80E tune or all tunes except stock?
