Sponsored by: Real Truck
bigger tires
Old May 19, 2009 | 07:21 AM
f-2501992002's Avatar
f-2501992002
bigger tires
ok i have a 2002 ford f-250sd 4wd and i have 245/75/r16 on it currently and i am wanting to put a 6 inch lift on and some bigger tires but i cant figure out what would be the perfect size i want something wider than stock tires but i cant afford rims what size should i get???? please help this is the 5.4 v8
Old May 19, 2009 | 07:32 AM
ffadragon's Avatar
ffadragon
First off with a 6 in lift you need to be running about 37" tires, but you really can't do that if you are not wanting to get wider rims. With your stock rims 285"s (33") is about all the bigger you want to go. But your truck would look a little goofy with 33's and a 6" lift.
I only have a 2.5" lift and I run 35's
Other things that really matter are you going to be doing any towing? are you going to be doing a lot of off roading?
Old May 19, 2009 | 07:45 AM
03_PSD's Avatar
03_PSD
Personally if you use your truck alot I think a 4" lift with 35's is pretty sweet looking.
Old May 19, 2009 | 08:10 AM
f-2501992002
ok i guess i dont under stand the whole 37 thing would they be like 345/?/? like what would i be looking for that and rims
Old May 19, 2009 | 08:29 AM
ffadragon's Avatar
ffadragon
Depends on how wide you want them.
Example
375/55/16 = 33-15.5-16
375/65/16 = 36-15.5-16
Most 37 in tires are labled 37" not 385.
It will just take some research.
First you have to figure what size rim you need 16,17,18,20 them also width of rim is dependant on width of tire. 12.5 inch wide tire needs to be on 9 or 10 in wide rim.
Old May 19, 2009 | 08:35 AM
f-2501992002
now will the 375/65/16 fit on the stock rims?
Old May 19, 2009 | 08:47 AM
f-2501992002
ok what about if i get 305/70/16 will those fit on the stock 16in rim??
Old May 19, 2009 | 09:06 AM
ffadragon's Avatar
ffadragon
305/70/16
Are 33" tall and 12.2" wide. You really need 9" wide rim for these. I think you said you had a 2002 which the stock rims are only 7.5" wide (you will end up with a lot of side wall bulge) and again 33" tire is very short for a 6" lift. You will have a lot of empty wheel well space. Maybe that is what you like though.
Old May 19, 2009 | 09:23 AM
03_PSD's Avatar
03_PSD
305's will fit a stock rim, so will 315's
Old May 19, 2009 | 10:11 AM
ffadragon's Avatar
ffadragon
Yes, they will fit, but I sure as hell wouldn't tow anything with them.
12.5 in wide tire on a 7.5 " rim isn't the safest thing in the world and your tires will not wear very well because the inner side wall are going to pull into the rims really bad. I know because when I switched my rims and tires, I had a bad rim show up, so had to put 1 of my 315 tire on my origianl 7.5 in rim for a week. even lower down to 35 lbs. I couldnt get the tire to wear all the way across because they were pulled in so tight.
Your tires will be shot in 25K.
Old May 19, 2009 | 11:20 AM
Furian's Avatar
Furian
You Keep What You Kill
Some 18X10 wheels with 4.5" of back spacing would be great for your Super Duty... just like the one's I have for sale in the Classified section of the forum.
https://www.ford-trucks.com/classifi...ct/27267/cat/5
Old May 19, 2009 | 11:32 AM
enduro4231's Avatar
enduro4231
Sounds like you're willing to compromise what you really want for the sake of not having to purchase new rims. If this is the case, you won't be happy with the end result and are just wasting money. If I were you, just purchase a set of used rims from someone and clean them up! I got my 16x9" Eaton black wheels for $100 from a buddy. Just look around, there are plenty on craigslist etc. Don't compromise, wait and get what you really want.
Old May 19, 2009 | 12:35 PM
Andershoberg's Avatar
Andershoberg
If you are serious about 37" I have a great deal for you: Rims and tires for a lot less than tires alone.
https://www.ford-trucks.com/classifi...ct/27201/cat/5
My Excursion came with these, and I am going to a street tire instead. Give offer, they ave to go.
Old May 19, 2009 | 02:23 PM
first_f250's Avatar
first_f250
im runnin a 2.5 inch kit with 285's and i want to305's when this set is gone someone told me that you cant run a 315 with just a leveling kit
Old May 19, 2009 | 02:45 PM
ffadragon's Avatar
ffadragon
I am running a 2.5 in leveling kit with 315's. I have 10" wide wheeels 4.5 in back spacing. The only thing I had to do is cut off 1 inch of the lower air valance and I have all the clearance in the world to run 315's. This is of course on a 04 Front leaf spring truck.
Coils up front may be different.but I doubt it
ucirlos
1997 - 2003 F150
Jun 16, 2015 06:22 AM
Farris Shaggy Jabaut
Dec 8, 2013 07:51 PM
Forddiesel11
Oct 15, 2012 06:22 PM
AC94EXPLORER
Dec 20, 2008 06:19 PM
