random stalling weird?
Old May 19, 2009 | 12:25 AM
So-Cal Sancho's Avatar
So-Cal Sancho
Great now its stalling. It has been doing it a few times over the last month. I'll becruising down the road no problem, I'll coast up to a light and it would die. no rough idle or anything just like you shut the key off. I would put it in park and she would fire right up. No problem for days. Now i went to park rhe truck and she just died in middle of street. This time she wouldnt start so i turned flashers on and noticed that i only had the passenger side flashing. still wouldnt crank.
Now i'm ready to call tow truck so I decide to check al lights and blinkers, everything worked but no start. Then turned flashers off and on then they both started working. Now truck started. From reading on here a lot of people have trouble with the dist or the pip. Would this mess up the flashers? Or possibly something else?
1996 f-250....460
Old May 19, 2009 | 07:03 PM
So-Cal Sancho
edit
it would crank and turn over just not start. Any ideas?
Old May 19, 2009 | 09:35 PM
MisterDave2's Avatar
MisterDave2
I had this with my 4.9 F150, also a 96, it made me crazy. I would start by going over all the basic stuff first. Filters, fuel pressure, check the wires, cap, plugs etc. Check the codes or have them checked. Check all the vaccuum lines. Another possibility is ignition trouble, the coil could be ng or the module in the distributer cutting out when heated up. Do a search, there's more info on this better than mine. I never got to the bottom of mine before I sold it to a mechanic who wanted my truck to rebuild it.
cjben's Avatar
cjben
I really doubt the flasher problem would be related to the stalling problem,I can't offer any advice on the flashers. Have you pulled codes? When the pip sensor went on the fritz on my 95,the symptoms were similar to what your truck is doing,and there was a code in the computer saying the pip sensor was bad.
Old May 20, 2009 | 12:55 AM
ford2go's Avatar
ford2go
If it won't crank, it's not your tfi or anything sophisticated like that.
Check your batt cables -- especially the grounds. Also check your ignition wiring.
If you meant to say that it would crank, but not start, it could be a lot of things. The computer is powered theough an eeciv relay ( at least they used to be). If the relay is bad, or the wiring to it is flaky, it could suddenly cut out.
tfis tend to fail hot, and they do recover.
However, the flashers may be pointing to a flaky ground somewhere.
Old May 20, 2009 | 08:01 AM
Gatorback's Avatar
Gatorback
Hello, I would second you on checking all your grounds because if the ECM circuit is
not properly grounded that could cause all kinds of flakey problems like stalling,
Good Luck,
John
_________
1988 F250
1979 F100
1978 F150
Old May 21, 2009 | 01:58 PM
So-Cal Sancho
update pulled code
Went out to the truck and pulled a code its:
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction .
what does this mean?
FordIowan
Dec 14, 2014 09:27 AM
Varqanir
Jun 7, 2009 07:00 PM
VikingBabe
Jun 3, 2005 02:30 PM
