Ok, so it looks like someone else has tried adjusting this thing. The top of the hold down nut is rounded off. I was able to get it adjusted and had the wife take it for a spin since I was covered in grease. Wife said it was a lot better..I'll drive it tomorrow and see. Thanks for all the help!
B.
Keep turning it in 1/4 turn until she starts binding on a full lock turn. Check you PS ATF if you haven't also.
Ok, drove it in this morning and much better but still needs a little more adjustment. Thinking I might do it again tonight..that airfilter is massive and a PITA to get out.
The filter is a little tricky but it only takes a minute if you do it right . Just swing it out of the way and leave it off 'till you're done testing.
