Aerostar Ford Aerostar
engine issues. Cyl #5 low compression.
Old May 18, 2009 | 09:52 AM
Pablo-UA's Avatar
Pablo-UA
hello friends.
seems to me my aero is ill.
well, about desease.
this winter I got cyl#5 spark plug goes out. I use to cleane it with sandblaster, heat on hob and engine runs well, but problem gets progressively frequent. Then, I got blue smoke and dissapearing oil. I have 7 BAR comression in this cyl, and when I crank engine with starter with disabled ECM I can hear that passing #5 cyl engine crancks faster.
I understand that I probably have failed piston ore rings and it is time to remove dr. side head and see what is inside. I wanna do it with engine in doghouse.
I wanna try to pull head carefully to reuse head gasket. I know that it is a bad idea, but I wanna save some $$ and I wanna use used piston (I have one 3.0 V6 with broken block).
Well, who did it? Any tips, that can help me )))....
Old May 18, 2009 | 10:05 AM
Bear River's Avatar
Bear River
Former ******
I haven't done this before. I don't think you'll have a problem with a used pistons, but pray tell, why don't you just rebuild another engine and swap them, then figure out what is up with the old one? I shouldn't be too hard to find a compatible rebuildable or usable as is engine.
As for reusing the head gasket, I would say that will probably not work. I would plan on at least replacing the gasket.
Old May 18, 2009 | 10:58 AM
Pablo-UA's Avatar
Pablo-UA
I was in Odessa this week, but I saw 4.0 only. No 3.0 on JYs. Taurus owners got all used engines!
Old May 18, 2009 | 11:02 AM
Pablo-UA's Avatar
Pablo-UA
well, i will start next week. I gonna let aero sit for a week and I will drive taurus only
