Sponsored by: Auxito
Weird keyless fob problem....
Old May 18, 2009 | 12:22 AM
maggy55's Avatar
maggy55
Fob doesn't work when its hot outside. Have 2 fobs and both behave the same . As soon as temp goes down , the fobs work again. Obviously its something to do with the truck itself. Any ideas ? Oh, 2001 F150 V6 2WD. Thanks
Old May 18, 2009 | 06:18 AM
shorebird's Avatar
shorebird
The Elf in your truck must be passing out due to the heat and can't press the unlock switch. But on the serious side do the locks respond to the lock/unlock switch mounted on the inside of the door? Do all the locks fail to work? Need to know to give an answer.
Old May 18, 2009 | 10:23 AM
maggy55's Avatar
maggy55
Yes, all the locks work normally if I use the door switches. When I use the fob, nothing. No clicking or other sound.
Old May 18, 2009 | 10:24 AM
Mawk's Avatar
Mawk
Probably a bad/faulty GEM on this one, too.
Old May 18, 2009 | 11:46 AM
maggy55's Avatar
maggy55
OK, what is a GEM and how do I fix it ?
Old May 18, 2009 | 12:57 PM
cowslinger64's Avatar
cowslinger64
I had to replace my fobs, but it was due to the little plastic rings being broken. I ordered a pair from the guy selling at the link below. I'm not a spammer and have no vested interest in his business. But, I got excellent service from this seller. Also, programming them myself, really couldn't have been any easier.
Scott
2 Ford Escape Expedition F-150 Keyless Remote Entrys !@:eBay Motors (item 270388694612 end time May-22-09 18:15:00 PDT)
Old May 19, 2009 | 03:31 AM
Mawk's Avatar
Mawk
Cowslinger, he posted that it doesn't work in hot temps, but when it cools down it works fine. Assuming that the key fob stays in his pocket, it'll usually be the same temp.
The GEM is the Generic Electronic Module that controls various electronics in the car including your powered locks.
If you do think it's the remote, open it up, clean the contacts with an eraser, and try that.
skscci
Mar 26, 2012 04:14 PM
ptf18
Dec 5, 2011 06:53 AM
fossyy
Jan 18, 2011 11:00 AM
Beamer 2
Mar 15, 2008 10:12 AM
AustinAG01
1997 - 2003 F150
Jun 29, 2007 08:47 AM
