Single function reservoir
Old May 17, 2009 | 06:06 PM
Jason6969's Avatar
Jason6969
Anyone have a picture of the inside of the single function reservoir? it seems someone has modified it by drilling a hole in one of the ports. The issue is fuel drain back, when you turn the key the pump runs a long time before cutting off. Does it contain any kind of relief valve? Has anyone ever eliminated it? It's on a van so I don't need the extra fuel supply for abrupt manuvers or climbing off road.
Old May 18, 2009 | 04:50 PM
subford's Avatar
subford
What year are we talking about (1980)?
What fuel system do you have (FI or Carb)?
Is this an after market fuel pump mounted outside the fuel tank?
Can you post a photo of this single function reservoir?
Old May 18, 2009 | 08:12 PM
Jason6969's Avatar
Jason6969
Thanks for the reply! It is a 88' E-150 w/4.9 single tank/ EFI. The single function reservoir is located behind the fuel tank and is plumbed in series between the low pressure pump in the tank and the filter and high pressure pump on the frame rail.The reservoir is a round black canister made of plastic.
Old May 18, 2009 | 09:24 PM
subford's Avatar
subford
The check valve is in the high pressure pump on the frame.
Sounds like your computer may going bad if the pump runs for a long time when you turn on the key.
It should time out in one second time period by the computer.
The running of the pump when you turn on the key has nothing to do with fuel in the fuel lines, it does not shut off on a fuel pressure build up.
Diagram of your fuel system:
Old May 19, 2009 | 06:21 AM
Jason6969's Avatar
Jason6969
Thanks, would that still explain the fact that it won't start until the pump shuts off? In other words ; if you hit the key a few minutes after a warm start up the pump cycles about a sec and then it starts up. If you wait about 15 mins to start the engine it won't start until the pump stops running; about 10-15 sec.
Old May 19, 2009 | 06:29 AM
subford's Avatar
subford
Yes it would and I have hear of trucks doing this before and it was the PCM Computer.
MI Yeti
WTB - Parts & other
May 9, 2017 08:19 PM
iwals
Feb 19, 2016 08:27 PM
bout-time
13
Mar 18, 2014 07:36 AM
predaina
29
Mar 29, 2011 07:07 PM
dabigisle
1978 - 1996 Big Bronco
Nov 16, 2006 04:06 AM
