vibration unknown
Old May 17, 2009 | 03:38 PM
jeter's Avatar
jeter
vibration unknown
I have a 93 F250 4x4 w/ 280,000 miles and an E4od trans. my problem is that i am getting a vibration in the seat constantly while i am driving. I jaked the front end up and checked all U-joints and ball joints. everything is good. i have noticed that everything is fine until i have to come to a fast stop. the vibration gets worse and then it pops. I am starting to think the transfercase chain has slack in it. Has anyone had this problem ?
Old May 17, 2009 | 05:15 PM
PLC7.3's Avatar
PLC7.3
If the truck is a super cab check the center hanger bearing in the drive shaft.
Please put up a signature with ALL your truck info...
Old May 17, 2009 | 07:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I think I would be inspecting the springs, shackles and frame mounts for the driveline.
Sounds like something is moving and binding in that position when you stop hard, the pop is when it returns to where it should be.
Something I have seen before is the spring center bolt shears off, which lets the axle shift to the front or rear.
You should be able to see an indication of that happening by looking at the U bolts that bolt the axle to the spring or by measuring the distance from the axle to the end of the spring on both sides and comparing measurements.
If that is happening in either axle, the driveshaft slip joint could be to close or to far open and causing the vibration.
On mine, the front axle to frame clearance was getting close to nothing, I thought the springs were getting weak.
When I hit potholes, I had this strange clunk I could never find.
So when I was changing the front springs, when I dropped the front shackles down out of the frame, I found why it was ridding low and where the clunk was originating from.
The upper bushing in the spring shackle was gone, the holes in the shackle side plates had worn to almost twice the size they should have been and the bolts were worn down to about 50% of what they should have been.
Just for grins I changed both of the front shackles and left the original springs under the truck to see how much difference they made, then I change the springs.
The difference in ride height was all in the shackles, the original springs were just fine.
That did not cause a vibration, but it the bolts/bushings on the rigid mount, rear front axle or front rear axle were worn, that would let the axle be out of line as well.
About 250,000 miles is when I went through all that with mine.
