flathead motor mount supports
Old May 17, 2009 | 12:12 AM
twise's Avatar
twise
hi guys, the previous owner cut out the front and rear motor mounts out of the frame. i recently found a flathead and tranny to put into my 52 but cannot find the mounting crossmembers online. does anyone have a source for these items. new or used would work. thanks
Old May 17, 2009 | 09:34 AM
wpkmik's Avatar
wpkmik
Are you talking about the L-shpaed mounts in front and the crossmember to hold up the rear/trans?
I had to find both of those for my '49. I got the front mounts from George Moir, out of Canada - 780.963.7334. Very helpful and I think very reasonable. I know Desert Valley Auto Salvage had them too, but he wanted almost 3x as much as I paid from Moir. Check there and see if they have more. I got the rear from Flashback F100 - 336.421.3979. I would try those 2 before Desert Valley. They seemed very expensive.
Hope that helps.
Old May 17, 2009 | 10:00 AM
51PanelMan's Avatar
51PanelMan
I have what you need for the front If you're putting a flathead 8 into a 52, then you'll also need the "lift" brackets that mount on the front curved brackets.
Look at this picture..
This was the set up in my 52 before I took out the flathead V8. The V8 is shorter in length and height, but wider than the 6 cylinder. The V8 mounts in the rear holes of the front brackets and needs the "lift" bracket in order to make it level with the transmission. (The 6 cyl mounts to the front holes of the bracket and doesn't need the "lift" brackets.)
I have the curved brackets separately from another truck (non-52), but I don't remember if they have the holes drilled for the attachment of the "lift" brackets. You could drill the required holes from a pattern that I can try and make for you. I also just took the "lift" brackets out yesterday when I installed a 215 back into my 52 from when it had a flathead V8 installed. I also have the old rubber engine mounts.
