Need Help (code blue stat)
Old May 16, 2009 | 08:13 PM
ChunderDownUnder's Avatar
ChunderDownUnder
I have disconnected the return line on the fuel bowl
Now Im tryn the feed line at the bottom.
The nut has come off - no worries - but for the life of me i cant get the tube out. I can see it is loose, but iI cant pull it out.
What am I doing wrong ???
was thinkn, does the tube come out or do I have to remove the whole sleeve that screws into the bowl ?
Old May 16, 2009 | 08:42 PM
ron's power stroke's Avatar
ron's power stroke
the rubber sleeve may be holding it in..i hope you have new ones..give it a good tug.it should come right out..here is what the ends look like when they unhook from the bowl
Old May 16, 2009 | 10:27 PM
ChunderDownUnder
New ones ???
oh dear. got impatient and ended up taking the whole sleeve out. Then while the tube was hanging there it come loose and the sleeve ended up in the middle of the engine valley
anyways got it back. There were a couple of spare sleeves in the CCK kit but the diameter on the feed tube looks to big for those. ??
Re installed with the original. You saying it wont seal ??
Old May 16, 2009 | 10:31 PM
big poppa's Avatar
big poppa
Nice pic Ron, changed mine out two weeks ago, the passenger side anyways.
Old May 16, 2009 | 11:01 PM
ChunderDownUnder
K , will deal with the seal later.
My next prob, is removing the air con bracket. Do you have to get rid of the tensioner first ?. there seems to be two bolts i cant get at because of the tensioner. I took out the top bolt above the tensioner assuming that was the one holding it in, but I cant budge it.
Old May 17, 2009 | 12:05 AM
ChunderDownUnder
All sorted
front port on air con back in, now for the rear then check everything then pray for no leaks.
f250macdaddy
Jun 6, 2014 01:15 AM
scottaklassen
Feb 15, 2011 08:06 PM
scubajt
Dec 28, 2009 03:39 PM
k_conner
18
Jul 4, 2009 12:23 PM
ChunderDownUnder
May 16, 2009 08:44 PM
