650 dashes are installed !
Old May 20, 2009 | 08:18 AM
  #46
Ponyboychris's Avatar
Ponyboychris
Does anyone have this version of the F650 dash? Just curious on how many gauges can fit on this version. I have 3 in the under the dash pod that I would like to install onto this dash but not sure if they would all fit. It looks like two can fit in the dash area to the left where the cubby hole would be and two right below it. Just thinking outloud.
Old May 20, 2009 | 09:53 AM
  #47
HighOctane's Avatar
HighOctane
PMS: an obsession
Chris, I bet you could fit 4 guages in that dash. 2 up and 2 below. Also, for those asking if this mod will work with a handshaker or manual transfercase shifter, (Matt) I am betting this one pictured above would work just fine. Brandon, we spend so much time improving our trucks, (now our dash) it has to be illegal not to turn all the switches to the same position when not in use!
Old May 20, 2009 | 12:27 PM
  #48
Ponyboychris
That's what I was thinking too. Maybe I will ask Ed to measure the spaces for me.
Old May 20, 2009 | 12:44 PM
  #49
dirty1's Avatar
dirty1
Thanks for that pic Chris and for the answer Ryan.
Chris do you have a part number for that piece?
Old May 20, 2009 | 01:50 PM
  #50
Ponyboychris
From Ed's website: Click me
Old May 20, 2009 | 02:47 PM
  #51
HighOctane's Avatar
HighOctane
PMS: an obsession
Just a tech tip for using the 2" hole saw on the dash. Russ and I found that our teeth pattern on our saw was pretty coarse, so operating the saw in reverse allowed for a super smooth hole to be cut into the dash. It's plastic, and once the heat starts it is like cutting butter. Almost beggered the hole on one dash with the teeth catching going in the proper direction. Also, with the holes that are already in the dash, to keep a consistent and solid anchor for the hole saw pilot, we simply duct taped a removed tin lid from canned goods to the backside. So eat soup for lunch and do this mod afterwards!
Old May 20, 2009 | 06:29 PM
  #52
superduty4x4's Avatar
superduty4x4
Originally Posted by bdrummonds
O.K. Ryan, I thought I was the only one OCD enough to turn all the AC ***** to the same position when not in use.
I'm guilty as well
Good tip! When I've used the hole saw on plastic in the past (snowmobile) I just run it in reverse long enough to get a groove started, then swap to forward rotation and it cuts super easy. Keeps the hole saw from walking and buggering things up!
Old May 20, 2009 | 08:02 PM
  #53
RussB's Avatar
RussB
Good tip! When I've used the hole saw on plastic in the past (snowmobile) I just run it in reverse long enough to get a groove started, then swap to forward rotation and it cuts super easy. Keeps the hole saw from walking and buggering things up![/QUOTE]
Thanks for that tip after we F'd mine up chase !!!! You're a little late on that one buddy ! If you notice in my ONE pic... There is an o-ring around my DP tuner gauge switch ! Thats to cover up where the hole saw walked a bit ! Although I do like the gauge being raised out a bit !!!! The gauge is tucked into those dashes quite a bit and if you bring it out it is more visible !
Old May 20, 2009 | 08:29 PM
  #54
rat49f6's Avatar
rat49f6
i want the 650 dash above i like it ... can anyone verify it will work with a 2wd 6 speed manual??
maybe some measurements???
Old May 21, 2009 | 05:51 AM
  #55
dirty1's Avatar
dirty1
Sorry double post.
Old May 21, 2009 | 05:56 AM
  #56
dirty1's Avatar
dirty1
Thanks for the link but it is not working for me.
I found the dashes of his site and I might take the plunge to get one.
Thanks again!
Old May 21, 2009 | 06:45 AM
  #57
bdrummonds's Avatar
bdrummonds
Here ya go!
Old May 21, 2009 | 08:00 AM
  #58
rat49f6's Avatar
rat49f6
thanks brandon...
now i cant wait to get off work and measure
anyone have the other (black one above) dash installed it looks like its lower profile
Old May 21, 2009 | 09:07 AM
  #59
superduty4x4
Well I never saw a post titled "looking for advice on using a hole saw" so I figured you knew what you were doing!
Old May 21, 2009 | 09:18 PM
  #60
RussB's Avatar
RussB
Good one buddy !! Ya got me there !
Hey Brandon..... what make of floor mats are those ???? I can't read the make in your pic ??? Husky ???????
