Loose Steering
Old May 15, 2009 | 06:57 PM
TheTech's Avatar
TheTech
Loose Steering
what i have: 79 150 351m auto trans and i'm not sure what kinda steering it has, im guessing stock... it steers like a tractor. The steering is especially loose on it and since the truck is lifted 6" this doesn't help me stay between the lines. Anyone know what kinda steering is on this, and is there a common upgrade/swap/modification i can do to make this thing steer better/straight?
Thanks
Old May 15, 2009 | 07:22 PM
4x4 Bart's Avatar
4x4 Bart
Your steering probably has excessive wear such as bushings, tie rods etc. Find a good alignment shop and have them check it out.
Old May 15, 2009 | 08:37 PM
Holiver31's Avatar
Holiver31
before taking it to a shop check the rag joint, it is between the upper and lower shafts just before the gear box.
