Serpentine Belt Split
Old May 15, 2009 | 06:42 AM
scatgo's Avatar
scatgo
Mine just threw chunks. It dont look good pieces of it tore up the insulation under the hood now I have fiberglass stuck all over my motor. Whats left of the belt is still on so I need to know how to get it off. The idler pulley looks like it is not straight so I might have to replace it. Any help will be appreciated.
Thanks
Old May 15, 2009 | 07:32 AM
plowhand's Avatar
plowhand
Playing in the Dirt
To remove the belt, put a socket with a long pull handle on the idler pulley bolt and move the idler pulley away from the belt, pull the belt off the idler pulley, slowly release the idler pulley, remove wrench, then work the belt off of the rest of the pulleys and over the fan to remove. Istallation is in reverse order (PAY ATTENTION TO THE BELT ROUTING ON THE PULLEYS)
If the idler pulley is out of aligmnet or loose/wobbly, replace the pulley assembly.
Old May 15, 2009 | 07:57 AM
scatgo's Avatar
scatgo
Just left and below the tension pulley there is a idle pulley that is missing the motor side of the flange that would ride the side or the belt. Is it Left hand thread? Its hard to get to with the fan and shroud in the way so I don't want to make things worse by tightening it.
Old May 15, 2009 | 11:57 AM
hoodjason's Avatar
hoodjason
it is a spring loaded tensioner. I think that I did the same thing when I first replaced mine. If I recall you should be able to push your breaker bar to the passanger side and the idler pully should slide out of the way. Unless it is real rusty it should not take too much effort to release the tension enough to slide the belt off.
Old May 15, 2009 | 12:00 PM
f250ssd's Avatar
f250ssd
Just cut it off with a knife, and there should be a belt routing diagram under the hood.
Old May 15, 2009 | 12:36 PM
scatgo's Avatar
scatgo
Belts off thanks. I am waiting on the idler pully that was broken.
Big Skier
31
Feb 27, 2019 07:21 AM
tseekins
General Automotive Discussion
Aug 28, 2010 03:44 PM
skierbri10
Feb 15, 2010 10:13 PM
krumpelsaurusrex
S. California Chapter
24
Jul 13, 2009 07:19 PM
dgeesaman
Apr 13, 2007 02:23 PM
