oil pressure fluctuating
Old May 14, 2009 | 11:35 PM
bandit68's Avatar
bandit68
the higher the rpms the less oil pressure. this is new to me when oil pumps go bad there is no pressure. this is a 89 f150 with the 5.0 engine
Old May 15, 2009 | 12:23 AM
Old93junk's Avatar
Old93junk
Sounds like a restricted oil pump screen, time to drop the pan......Check it with a mechanical gauge first.
Old May 15, 2009 | 04:08 PM
bandit68's Avatar
bandit68
thank you for the suggestion.
Old May 15, 2009 | 04:43 PM
lew52's Avatar
lew52
I agree pump screen . The oil pump is normaly not the problem. You will find out if you have to drop the pan ?? Lew
Old May 15, 2009 | 05:00 PM
andym's Avatar
andym
I third the pump screen. You will have to jack the motor up enough to get the oil pan out from underneath. This can get involved, as the upper intake and sometimes the exhaust manifolds have to come off. And you will have to loosen the motor mounts obviously.
Old May 17, 2009 | 07:51 PM
bandit68's Avatar
bandit68
was 2 problems screen and bad gauge
Old May 17, 2009 | 09:31 PM
quicklook2's Avatar
quicklook2
the screen design easily clogs.
glad you fixed the problem.
