Sway control- OBS vs. SD
Old May 14, 2009 | 07:00 PM
superduty4x4's Avatar
superduty4x4
Some history here- my old truck was a 95 F250HD, XLT, extra cab long box, 460/auto trans, 4x4. 265/75/16 rubber on aftermarket aluminum rims. Being an HD model with various options (trailer tow and camper package IIRC) it had beefed up suspension all around (basically F350 spec suspension) and sway bars front and rear.
My 99 F250 has the standard issue wimpy front and rear springs, a stock front swaybar, and an aftermarket rear sway bar. 285/75/16 rubber on OEM rims. Granted its quite a bit heavier than my old truck, but I'm amazed at how much more unstable it is when loaded down than my OBS was.
My question is, what can I do to get some stability back? I'm looking into adding OEM overloads to the rear springs, considering an OEM swaybar to replace the one I have, and see what that gets me. If I'm still not where I want to be, then X codes up front, then onto airbags if I'm still not happy.
Yes, I'm excessively **** retentive so don't bother pointing that out to me
Old May 14, 2009 | 09:04 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I use an add a leaf front and rear. I have zero sway ever. The empty ride can be punishing at times, but the big girl will flat out turn a corner.
Bigger sway bars will help a lot running empty, but there is only so much they can do when the springs are squashed. X-codes and a rear leaf will likely accomplish your goal.
Old May 15, 2009 | 12:00 AM
rebelchevy02's Avatar
rebelchevy02
I agree on the front springs. My truck has a V codes, and an extra full length leaf. Also a replacement rear pack, that is enormous. Takes a turn like a champ, and sits were I like it, and I do notice if the front swaybar is disconnected, so I would go for X codes, and then whatever it takes to level out the rear. You will more then likely be happy. I dont have a 5th wheel, but I do pull a big tandem axle bumper pull, with a pretty big skid loader on it, and have absolutely no sway issues.
jimcar-9
25
Apr 18, 2014 10:24 PM
DBLX
2009 - 2014 F150
Mar 23, 2014 09:53 PM
KhanTyranitar
Aerostar
53
Aug 31, 2013 08:34 PM
Bootlegger's Deluxe
Mar 3, 2011 07:31 PM
ErrorS
Offroad & 4x4
19
Feb 28, 2010 02:39 PM
