Shift Interlock, Power Windows, Wipers
Old May 14, 2009 | 05:33 PM
psg2628's Avatar
psg2628
Question Shift Interlock, Power Windows, Wipers
What would have caused all 3 of these to go out at the same time? It is not fuses, I already checked them. This has me stumped.....
Old May 14, 2009 | 05:40 PM
87 XLT's Avatar
87 XLT
What are you driving???
Old May 14, 2009 | 05:43 PM
psg2628's Avatar
psg2628
guess that would help wouldn't it.
this is in an 01 F150 supercrew with 5.4L
Old May 14, 2009 | 06:12 PM
Franklin2's Avatar
Franklin2
Look for water damage in and around the fuse box and the gem module under the left side of the dash.
Old May 14, 2009 | 06:26 PM
87 XLT's Avatar
87 XLT
Well I dont have diagrams for an 01 F-150, but have you checked for voltage at the shift lock fuse?
This probably gets 12 volts directly from the ignition switch with the key at run.
The other side of the shift lock gets voltage from the brake light switch.
Are your brake lights working??
