Stalling when Cold
Old May 14, 2009 | 04:27 PM
Lower Deeezy's Avatar
Lower Deeezy
Stalling when Cold
what are the main causes for an engine to stall when its cold but not when its warm
my 78 f150 is doing it to me
Old May 14, 2009 | 05:28 PM
TheTech's Avatar
TheTech
that's the nature of a carb to be honest. but you might check vacuum, bad gas, air cleaner, idle mixture.
Old May 14, 2009 | 06:28 PM
montana_highboy's Avatar
montana_highboy
Check to make sure the choke is operational.
Old May 14, 2009 | 06:29 PM
Jermafenser's Avatar
Jermafenser
Tune your carburetor. Choke may be maladjusted.
I can start mine at 20F with only one stroke.
Old May 14, 2009 | 06:32 PM
TheTech's Avatar
TheTech
how do you adjust the choke on these?
motorcycles are a bit different im assuming which is what im used to
Old May 14, 2009 | 06:34 PM
Jermafenser
First you're going to need to check the choke pulloff diaphragm to make sure it has the ability to hold vacuum. If it doesn't, replace it.
Then you need to check your choke pulloff. After that, the fast idle cam be aligned properly. Then the choke should be set to factory specs.
Do a search here on in the fuel forum - it's been covered recently a few times.
Old May 14, 2009 | 07:01 PM
fmc400's Avatar
fmc400
MSEE
https://www.ford-trucks.com/forums/8...ml#post6939116
https://www.ford-trucks.com/forums/7...ml#post6422219
Enjoy!
Old May 14, 2009 | 07:08 PM
TheTech's Avatar
TheTech
you are THE MAN!! thanks fmc
Old May 14, 2009 | 07:40 PM
Lower Deeezy
thanks alot guys
Old May 14, 2009 | 08:27 PM
shanes66charger's Avatar
shanes66charger
easiest thing to do Is just install a manual choke and let the engine WARM up before hitting the road.
Old May 14, 2009 | 09:37 PM
shadowviper12345's Avatar
shadowviper12345
could be a bad thermostat, easily tested just put a vacuum on it and see if it moves
Old May 14, 2009 | 11:17 PM
79FordBlake's Avatar
79FordBlake
I prefer a manual choke also. I like to control engine speed myself when its warming up.
460swmo's Avatar
460swmo
I got to agree with Jermafenser, I set my Motorcraft 2150 to work with all the factory parts and adjusted properly including the choke pull off, the choke itself, and the duct from the exaust manifold to the air intake, all intact and working properly I can start my truck even below zero after one pump to set the choke, it starts right up and fast idles on it's own perfectly.
