Boost gauge question
Old May 14, 2009 | 04:13 PM
pwstroker69's Avatar
pwstroker69
OK, I have my DP on the way (or it shortly will be) and am ordering the ISSPro gauges. I assume with no engine mods other than the tunes, the 0 - 30lb boost gauge is the one I need? Are the higher boost gauges just for modded turbo's and or engines?
Thanks, David.
99.5 Crew, 2WD, 6637, batt box & meffler delete, otherwise stock.
Old May 14, 2009 | 04:16 PM
HKusp's Avatar
HKusp
You can get away with the 30, but I went with a 40 just in case.....
Pms...aaaaahhhhh
Old May 14, 2009 | 04:21 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
I have a 40 as well but like HKusp said a 30 would be fine. I guess I have wishfull thinking.
Old May 14, 2009 | 05:00 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
x2 from above. 30psi is plenty unless PMS gets ahold of you and you get a 38R
Old May 14, 2009 | 06:18 PM
superduty4x4's Avatar
superduty4x4
I have the 30psi, works great for a mostly stock truck.
Old May 14, 2009 | 06:25 PM
big poppa's Avatar
big poppa
Yep, the guys are right, if you planing on modding with a bigger turbo or injectors and so on, get the 40, I got a 38R turbo and a 30 boost and I can peg it at 30 if it doesn't defuel first, I'll be getting the 40 boost gauge somewhere down the line.
Old May 14, 2009 | 08:00 PM
pwstroker69
You guys are the best. Thanks for the answers, exactly what i was looking for, from those who use 'em. I'm getting the 30 as I don't plan on doing much else for performance and I don't scream on it,.....often!
David.
Old May 14, 2009 | 08:14 PM
4inchlovin's Avatar
4inchlovin
Mine goes to 99..... hehehe Gotta love Digital... LOL
Old May 14, 2009 | 09:47 PM
CSIPSD's Avatar
CSIPSD
Depending on what gauges you get, EV, get the 30, there cheap enough that if you ever go bigger (and you will) you can buy another one easy... But if you go EV-2 get the 40#... There a bit more, but I much rather prefer the electric gauges for boost...
