Coolant Lines?
Old Jul 28, 2002 | 04:26 PM
tweetch's Avatar
tweetch
Coolant Lines?
Can someone tell me from which end of the trans. the hot oil is going to the radiator from? I need to know if the oil goes from the fitting at the beelhousing end or from the fitting at the driveshaft end of the tranny. TIA tweetch
Old Jul 28, 2002 | 09:58 PM
Mike W's Avatar
Mike W
Coolant Lines?
I really don't think it matters. The cooler in the radiator is just a tube with fittings on it.
Old Aug 2, 2002 | 06:34 AM
rebocardo's Avatar
rebocardo
Coolant Lines?
Most likely the hot line is the one at the bellhousing, I doubt you could feel much of a temp. difference touching the lines, and as posted earlier it does not make much of a difference.
Old Aug 2, 2002 | 08:36 AM
KJKozak2's Avatar
KJKozak2
Coolant Lines?
