Sponsored by: Auxito
Trans gauges...
Old May 13, 2009 | 11:19 PM
lilman320's Avatar
lilman320
Trans gauges...
Hey everybody, I'm looking to install a trans temp and/or trans pressure gauge in my truck, it's a 1999 f-150 5.4 auto. My question is where is the best place to put the sending units because i am clueless when it comes to automatic trannys
Later,
Willie
Old May 14, 2009 | 09:40 PM
KingRanchMan02's Avatar
KingRanchMan02
If you don't get much help here, go down to the forum on the 4R70W transmissions and post the same question there. Good luck!
https://www.ford-trucks.com/forums/forum69/
Last edited by KingRanchMan02; May 14, 2009 at 09:43 PM. Reason: Added a link to the proper forum.
Old May 15, 2009 | 01:07 AM
Bear River's Avatar
Bear River
Former ******
I would put in in the trans pan. That gives a good indication of the overall trans temperature. You will probably need to have it welded on, though there may be kits that you can drill and bolt on.
