Brake Question (7.3l idi)
Old May 13, 2009 | 11:08 PM
Fontucky Slim's Avatar
Fontucky Slim
Hello and thanks in advance for the help.
I did a search but did not find what I was looking for. I have a 1990 F350 crew cab, with 7.3l idi, and 35 inch wheels. Thats a lot of truck to slow down but I am pretty sure 1 ton brakes should be a little more powerful than mine are right now.
Ok, now the tech stuff. I know that there is a relationship between the power steering pump and my brakes. My pump is leaking and is pretty close to shot. If I replace the pump, will I have more pedal and stopping power?
Old May 14, 2009 | 04:16 AM
Lazy K's Avatar
Lazy K
If you have the hydraulic booster then it depends on the power steering pump but so does the power steering. Is your steering heavier than usual?
Have you had the rear drums off? Might be worth checking condition of shoes and checking the wheel cylinders to make sure they are not seized.
Hope this helps.
Old May 14, 2009 | 08:23 AM
Fontucky Slim
Hope this helps.
Helps alot, thanks. That will give me a couple of starting points. Yes, the steering is heavier than usual....
Old May 14, 2009 | 09:47 AM
Lazy K's Avatar
Lazy K
Then, assuming the drive belt is good, it`s time for a replacement pump.
