1978 - 1996 Big Bronco
460 conversion questions. please help!
Old May 13, 2009 | 03:14 PM
Curt13's Avatar
Curt13
i am trying to put a 460 in my 88 bronco that originally came with the 300 and the c6. i need to know what kind of adapter (if any) i need to use to bolt it up to the c6. also i have thought about maybe goin with a manual. what would be the best one to put with the 460? and how would i go about doin that?
Old May 14, 2009 | 12:36 AM
Kemicalburns's Avatar
Kemicalburns
you need a big block C6 tranny or a manual tranny with the big block bolt pattern. you wont find an adapter plate. you will also need specific mounts, different radiator.
that 300-6 is efi right so are you going efi on the 460?
Old May 14, 2009 | 01:16 AM
mattsautobody442's Avatar
mattsautobody442
go with an efi 460 and big block c6, there dirt cheap
Old May 14, 2009 | 11:17 AM
bertha66's Avatar
bertha66
I have a 460 in a 80 Bronco, it is a car engine. The frame on the passenger side had to be cut for the exhaust. I ungerstand that a engine out of a truck with truck manifolds does not need the frame notched.
Old May 14, 2009 | 05:19 PM
Kemicalburns
well the motors from car or truck are the same Bertha, but the manifolds would infact make a huge difference.
