diesel frames the same?
Old May 12, 2009 | 08:11 PM
69crewcab's Avatar
69crewcab
anyone know if an 84 f-250/350 diesel truck uses the same frame if either 2wd or 4x4?? I see the 4x4's seem to have the same crossmember in the front were the diesel is mounted too.. Can anyone confirm/?
Old May 12, 2009 | 08:48 PM
Kuskoal's Avatar
Kuskoal
i would imagine the 2wd frames were lighter duty because they kept coil springs and the 4X4 were freakin tough. i dont think a diesel vs. gas frame is different
Old May 12, 2009 | 09:33 PM
WA1986F-250's Avatar
WA1986F-250
With respect to F-250/F-350s...Diesel vs. gas the frames are the same. The frames are different between 4x4 and 2x4 due to the leaf spring mounts in the front of the 4x4 frames. Other than that, it is the crossmembers (can be interchanged) that are different between 2x4 and 4x4 due to the different suspension components and transmissions. The engines just use different mounts on the engine cradle. Frames on F-350s are different between dually and non dually (closer rails on dually), but that's not what you asked.
Old May 12, 2009 | 10:01 PM
Franklin2's Avatar
Franklin2
Only thing different on a diesel is the radiator support for the larger radiator, but I guess that is not considered part of the frame.
Old May 13, 2009 | 06:21 AM
82F100SWB's Avatar
82F100SWB
The 460 and diesel trucks run a slightly different shaped engine cross member than the gas trucks, but, it's a non issye when it comes to any mounting positions.
Old May 13, 2009 | 06:36 AM
redbug's Avatar
redbug
I have an 85 Diesel 4x4. And it has leaf springs on front. Boy, what an awful ride unloaded. I would rather tow a heavy trailer, makes it ride better.. I have the non-extended cab. On a long trip it tires me out....
