Sponsored by: Real Truck
help.. what do I need to do?
Old May 12, 2009 | 11:50 AM
crashedct's Avatar
crashedct
help me out please.. I am getting totally different info from everyone I speak to regarding what I can fit with my current setup.
here's what I have.. 2006 F350 6.0 with Bilstein BTS system @ icon TEI spacers up front.. +/- 3.25 -3.5 lift and 5" rear blocks.
Currently, I am running 325/60/18 baja claws on 18x10 Classic II 4.5" bs - which rub at full lock.
here's what I would like.. 325/65/18 MT Baja ATZ's on whatever rim size/bs would work...
please help.. I only have $$ to do this once. any pictures and specifics would be greatly appreciated... thanks.
Old May 12, 2009 | 04:13 PM
ReAX's Avatar
ReAX
The MTs will be 5% taller, so about a half an inch taller and slightly more than .25" on each side. The width is unchanged, as both are 12.79" or there about.
With the tire/wheel combo you have, 4.5" of the wheel sticks behind the flange. So 6.4" of tire minus the .5" of offset and you have 5.9" of tire behind the flange. Your tire is roughly 33.35" in diameter, but my trig gets messy here.
