F100 bed
Old May 12, 2009 | 09:24 AM
82-100's Avatar
82-100
F100 bed
I have a question for you guys, I have the bed off my f100 and thought I would just buy a new one since it is rusted out REAL BAD. The po used cardboard newspapers and bondo to try to fix it which just made it rust out more when it all got wet. So my question is should I try to fix my bed or continue looking for a replacement. The problem is I don't wanna put out the cash for a brand new one and all the ones I find at the yard are rusted just as bad as mine. I looked into using some of those patch panels from lmc but I'm not much of a body man. If I went that route how hard is it to install these panels? Anyone ever used them?
Old May 12, 2009 | 10:44 AM
quaddriver's Avatar
quaddriver
you can fix it yourself if you understand body work when welding in panels.
but then expect to hear these words:
"you made your bed, now sleep in it"
bwahahahahha
Old May 12, 2009 | 10:51 AM
82-100's Avatar
82-100
lol now thats funny I dont care ya are....just a thought but could i just get one of the panels that is larger than the hole and glue it to the bed then grind it down and use some bondo to smooth it out. Im not very good at welding and know i would burn through it the first try. Keep in mind this is just a daily driver not a show truck.
Old May 12, 2009 | 11:29 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Many shops are using adhesive these days.
No welding, No warping!
Personally, I like my vehicles welded together, not glued!
-Enjoy
fh : )_~
Old May 12, 2009 | 11:59 AM
82-100's Avatar
82-100
Well LMC has the panel I would want for 39.95 a piece so that would give me basicly a new bed for 100 bucks. The sections I want are 26"x59" so that is pretty much the entire side and the inside of the bed is in great shape. So does anyone know of a good glue to suggest.
Old May 12, 2009 | 12:49 PM
Franklin2's Avatar
Franklin2
I don't see how you are going to glue it. Even when you weld it, you have to use screws to pull it together for a tight fit. I would use flange pliers to offset the joint, and just use pop rivets.
Old May 12, 2009 | 01:13 PM
88-150's Avatar
88-150
Gorilla Glue? I'd feel better if my bed was welded instead of pop'd or glued. You could probly take the parts to an auto colision place and they could weld it for you if you don't want to weld it yourself. Just my 2 cents.
Old May 12, 2009 | 01:30 PM
82-100's Avatar
82-100
There is a place up the road from me Ill see what they will charge me to weld it on and I can do the rest.
Old May 12, 2009 | 01:33 PM
88-150's Avatar
88-150
It shouldn't be alot and you'd be paying for labor since you have the parts already.
Old May 12, 2009 | 01:39 PM
Festus Hagen
Methanoholic
Fit it up, Put a few POP rivets in to hold it together and take it someplace and have it welded.
Don't get me wrong, POP rivets are great, Adhesives are great, they have their uses, this is not one, IMNSHO!
Regardless it needs to be flanged, if it's not already.
Take a look on the powerblocktv site, they've probably used adhesive.
Some say it's stronger than a weld!
-Enjoy
fh : )_~
Old May 12, 2009 | 03:39 PM
Redneck1465's Avatar
Redneck1465
Personally I would weld it but thats just me...
Old May 12, 2009 | 03:41 PM
82-100's Avatar
82-100
You know on second thought I think I will just use some duct tape and bailin twine....haha. On a serious note I called the shop to find out what it would cost which means they want to look at me and see how much money they think I have.
Old May 12, 2009 | 03:43 PM
Redneck1465
While your at it use the gum your chewing too I have heard that works pretty well
Old May 12, 2009 | 03:48 PM
88-150's Avatar
88-150
well there's always the Gorilla Glue.. they want alot?
Old May 12, 2009 | 04:10 PM
82-100's Avatar
82-100
You know I have alot of gorrilla glue for my woodworking projects but I dont know how well it will work with the bed panel because it swells so much.
