New question
Old May 12, 2009 | 01:30 AM
Jeff Dodson's Avatar
Jeff Dodson
New question
05 EXPY EB, the there is something wrong with the rear AC. When you turn it on the is a clicking sound in the rear compartment on the passenger side in the back. I could probably fix it but I cant figure out how the get that rear cover off to see inside. I dont want to break any of it, How do I remove the cover
Old May 12, 2009 | 07:42 AM
alwaysfords41's Avatar
alwaysfords41
It sounds like it is one of the two blend door actuators. Search on that topic - there is detailed info on how to diagnose which one it is, and how to change it. You may also want to search rear climate control and thumping, which is the noise it usually makes when they go bad.
Old May 14, 2009 | 06:16 AM
Jeff Dodson
OK, I need to know how to get that panel off without breaking anything
Old May 16, 2009 | 06:34 PM
Jeff Dodson
N O B O D Y , knows how to remove the rear panels in here.
Old May 17, 2009 | 07:25 AM
alwaysfords41
Dude, I told you what to look for. The info is on the site. It took you two days to respond to my message offering help, but if someone doesn't get back to you right away you get all pissy. In case you still haven't helped yourself, the easiest one to check is the floor to ceiling blend door actuator. It is roght below the little change tray on the right rear quarter panel. pop the change tray off by flexing the long sides inward, it is held by little arrow head barbs so once they clear the opening they are snapped into it willcome right out. Disconnect the little beige box right under the change tray from it's harness. If the problem goes away, then that's your problem. Try that first, the other on is harder to get at.
Old May 18, 2009 | 07:07 PM
Jeff Dodson
DUDE, I didn't get pissy, this is what I was looking for THANK YOU !!!
IowaJack
2009 - 2014 F150
Dec 17, 2014 12:09 PM
PRexcursion
Nov 18, 2011 06:53 AM
sillyp
Sep 15, 2004 06:46 AM
jamesj
Sep 1, 2004 11:31 AM
8ACHEVY
May 11, 2002 02:02 AM
