1976 Super Cab engines possible
Old May 12, 2009 | 12:47 AM
williamm21's Avatar
williamm21
If the year had several engine options is it plausible to think my truck will take any of those engines without modification?
Old May 12, 2009 | 04:49 AM
miottimouse's Avatar
miottimouse
provided you have the motor mounts and frame stands there is 3 holes in the frame on each side depending on which motor combo you are using you can go from a i6 to a 460 and every thing in between useing the right hole/stand/mount/engine/trans combo and the trans pearch will bolt up [automatic] exaust p.s. pump alt brackets will all be different mind you
