need help indentyfying block?
Old May 11, 2009 | 03:19 PM
shaggy5935's Avatar
shaggy5935
i have a 400 planing on building i already verified its a 400 and run numbers and head it started with d5 i found that to be 1975 block if im correct. not sure? and next to the oil pressure unit i found numbers and factory stamps but there real hard to make out and i was told that in there it should say cf or mcc depending where it was cast also was told if its says mcc to get the block with cf said had a tendency to crack?
Old May 11, 2009 | 05:14 PM
03scf250's Avatar
03scf250
Here is a link to a very informative site on M blocks. M-Block 351M/400 Parts Reference It should help you with all the casting # questions you have.
