TTB question...
Old May 11, 2009 | 11:51 AM
Brown Falcon's Avatar
Brown Falcon
TTB question...
Did they make a 3/4 or 1 ton front for our trucks or similar that had coils springs???
I thought that I had heard of a D50 TTB with coils once...
Old May 11, 2009 | 12:09 PM
Neal 97 250's Avatar
Neal 97 250
The coils were on the SD's and they were solid axles. For our trucks if it is 4WD it is leafs.
Old May 11, 2009 | 12:17 PM
Brown Falcon
I'm just wondering if there's any way I can make my coils work with a front axle... or if it would just be easier to put leafs up front
Old May 11, 2009 | 12:23 PM
superduty4x4's Avatar
superduty4x4
You're trying to convert to 4x4? Forget the TTB and get a D60 straight axle. You could probably mod it to run coils, but it would probably take a ton of work. On that note though, it may take a ton of work to make a pair of leafs fit in your 2wd (spring perches etc).
Old May 11, 2009 | 12:30 PM
Brown Falcon
I've got a '88 4wd F350 back home in Oregon... but I'm stationed out here in NC for at least another 2 years.
I was planning on taking everything from the front of my '88 and swapping it in. Or if the frames are the same I could swap everying onto the 4wd frame... It also is a 5-speed truck so I was thinking about doing a 4x4 and manual swap all at once
Old May 11, 2009 | 12:57 PM
superduty4x4
Gotcha. Where at in OR? I was a short-time eastern OR resident.
I don't think the frames are identical, so you'll probably be better off swapping the stuff to your frame.
Old May 11, 2009 | 01:19 PM
Brown Falcon
I'm from Corvallis, home of Oregon State U.
I love Eastern Oregon, always out there hunting and fishing...
Old May 12, 2009 | 01:25 AM
joe_13894's Avatar
joe_13894
Heya from Dallas, OR.
Old May 12, 2009 | 06:34 AM
Brown Falcon
Wow, seems to be alot more diesel guys on here from Oregon than NC... wish I was back home, probably won't be able to move back for another 6 years if I re-enlist
I'm thinking I'll swap in leaf springs when I'm ready to do the swap
Old May 12, 2009 | 09:35 AM
jle70's Avatar
jle70
Thank you for your service!
I also am looking into swapping my TTB for a solid axle. I just need to check gear Ratio.
Old May 12, 2009 | 10:27 AM
Brown Falcon
Well thank you for your support!
Right now my truck is 2wd... so I'm trying to get parts together to do a 4wd swap. It's my daily driver so I won't mind having the TTB front, I won't be abusing it offroad, just some camping trips, snowboarding, stuff like that. I want 4wd in those kinds of situations, but my '88 F350 is gonna be my offroad rig.
Old May 12, 2009 | 11:12 AM
superduty4x4
A straight axle is a much better option, but if you can get the TTB free or cheap that may be an okay option.
