Coil Spring Tag
May 11, 2009 | 08:07 AM
Coil Spring Tag
What does this coil spring tag mean (5C34 5310-ADB 5AD) Located on a 2009 F250 4X4
May 11, 2009 | 08:45 AM
Just the part # that was used.
May 11, 2009 | 09:27 AM
Rep points added for getting under the truck. Someday we will get you to mod that bad boy!!
May 11, 2009 | 12:54 PM
Thanks now can you tell me what rate the springs are from that number? IE: 5600 lb or 6000 lb rating?
May 11, 2009 | 12:58 PM
May 11, 2009 | 01:03 PM
Ok, I am not able to do that since it isn't my truck. Otherwise, I would. Can this information be obtained from the info provided?
Thanks
May 11, 2009 | 01:06 PM
Someone else will have to chime in but I don't think so unless you pull a build sheet from the dealer. You would need the vin for that.
May 11, 2009 | 01:21 PM
May 11, 2009 | 01:23 PM
Quote:
Originally Posted by
harleyrules
They are 5,600 lb springs. 5C34-5310-ADB is the engineering number. 5C3Z-5310-DA is the service part number...
May 11, 2009 | 02:31 PM
Power Stroke,
Thank you very much.
May 11, 2009 | 02:35 PM
And thanks to Heavy also.. Good article
kaneabel
Jul 27, 2016 06:19 PM
ncheavymetal
North Carolina Chapter
Jun 29, 2016 08:34 AM
Notmeofficer
Mar 31, 2016 02:22 PM
strokin83
6.7L Power Stroke Diesel
Jan 26, 2016 02:45 PM
Ben_E
1983 - 2012 Ranger & B-Series
Aug 13, 1999 10:27 PM
