diff oil leak
Old Aug 15, 2002 | 09:24 PM
Mike W's Avatar
Mike W
diff oil leak
Old Aug 17, 2002 | 11:26 AM
tomrolf22's Avatar
tomrolf22
diff oil leak
Have just installed a rebuilt 9 inch rear in 40 ford pickup. have oil leaking from rear, appears to be leaking from pinion nut area and not the seal. Is there a seal behind nut and washer??? What to do ???
Thanks, Tom
Old Aug 20, 2002 | 01:05 PM
DIFFMASTER's Avatar
DIFFMASTER
diff oil leak
There is no seal behind the pinion nut, the problem is worn splines on the yoke and the gear oil is pushing itself through the splines. Ford has very soft yokes and common practice for us is to put a film of sealant on the bottom of the yoke splines before assembly.
