NP435 Grinding
Old Aug 16, 2002 | 03:31 PM
truckn's Avatar
truckn
NP435 Grinding
I have a 84 bronco with a NP535. At first I had to realease the clutch a little to engage 1st gear, so I replaced the clutch, pressure plate and bearing. While I had it torn apart I put in a new flywheel. It still has the same problem and now it grinds from 1st to 2nd. I notice when I down shift it will grind at 2500RPM. Is my linkage going bad? I changed the fluid when I replaced the clutch. Whats the deal?
Old Aug 22, 2002 | 11:17 AM
RockyMtnF250's Avatar
RockyMtnF250
NP435 Grinding
I had the same problem with my NP435. The aluminum second gear synchronizer cone sheared the rivets that held it on it’s mount. This was on a Saturday, no one locally had a new one. A friend of mine at a gear shop used regular pop rivets(!) to put it back together, I was skeptical but I needed to run the truck, I ran it three years this way. A couple of months ago, when I had my engine rebuilt, I installed a rebuild kit that included new syncros, the pop riveted syncro was still holding together but was racking on the rivets a little bit.
Wes
Old Aug 22, 2002 | 12:43 PM
truckn's Avatar
truckn
NP435 Grinding
THANKS. I will look in to that and hope that it solves the problem.
Old Aug 22, 2002 | 02:03 PM
jopey's Avatar
jopey
NP435 Grinding
KevinVf250
Oct 1, 2014 05:29 PM
Jason Neuman
Aug 15, 2012 10:00 PM
custom1106
13
Mar 18, 2011 07:17 PM
1969furd
Nov 7, 2010 09:40 AM
truckn
1978 - 1996 Big Bronco
Aug 20, 2002 02:03 PM
