I suggest you avoid it though. You can get the same amount of lift using a 2.5" AS front, and 3" rear kit. Run you less than $200 for them shipped
The Ranch Quick Lift is a waste of money IMO...the only reason I can see using it, is if you need new front shocks...even then, I'd use Bilstein Leveling shocks instead.
