Vacuum modulator
Old Aug 19, 2002 | 10:56 AM
loudfords's Avatar
loudfords
Vacuum modulator
How do I tell which modulator is in my tranny? I went to buy a new one and I had my choice of 3 different single diaphagm and 1 double diaphragm. There were colored stripes on the singles. Mine is just rusty. The tranny is a C6 from an 88 E250 or E350. It is a heavy duty tranny with higher stall convertor.
Old Aug 19, 2002 | 08:50 PM
kennethl6's Avatar
kennethl6
Vacuum modulator
If you have to guess at what you had, go will the purple or green stripe single hose modulator.
Old Aug 20, 2002 | 10:55 AM
loudfords's Avatar
loudfords
Vacuum modulator
What are the differences between the different modulators?
Old Aug 22, 2002 | 08:39 PM
kennethl6's Avatar
kennethl6
Vacuum modulator
The difference between modulators are the spring tensions on the diaphragm. I use to have a list of the spring rates on the different units but I can't find it. I will say that I see the purple and black band mod. in trucks the most. There is a screw adjustment in all of them to make minor shift feel changes. I've found you can install any one of them and the trans will normally work fine.
Old Aug 22, 2002 | 08:54 PM
RoadRash's Avatar
RoadRash
Vacuum modulator
