Shifting points
Old May 10, 2009 | 05:28 PM
skeelo's Avatar
skeelo
Question Shifting points
I Have a 77 F250 with a 351m. Just rebuilt the motor and put on a new 4 bbl carb. The 351m is happier now! but at what speeds should it shift at WOT? What speed should be the max that you could go in first and second? I don't have a tach yet and i don't want to blow the new motor.
Old May 10, 2009 | 07:14 PM
BIG-IRON's Avatar
BIG-IRON
2500 to 3500 rpm
Old May 10, 2009 | 07:46 PM
wyazel1's Avatar
wyazel1
It all depends on your setup. I just installed the TCI streetfighter valve body in my c6 and in D it shifts 1-2 at 5500 rpm But my motor has a few non-stock goodies also, a stock motor wouldnt like that very much.
depends on your gear ratio for what speed it will shift also. pretty much i think we need more info to give you a good answer.
Old May 10, 2009 | 09:12 PM
Pickupmanx2's Avatar
Pickupmanx2
#1, BUY a tach!! And yes it depends on your gear ratio, and tranny, since you are shifting, I am guessing it is a 4 speed?! I usually run mine up to about 35-4000, course when I get down to hwy 41 and head to town, it is straight up hill from a stop, so I tend to wind em up pretty good, I have gone over 4000 on accident (was still trying to shuffle coffee from hand to hand) but he didn't like it much...
Old May 13, 2009 | 12:21 AM
skeelo's Avatar
skeelo
I have a C6 that has been rebuilt but nothing changed with the gear ratio. The rear end is stock. Everything is stock on the truck except the new carb. What is the red line on the 351m?
Old May 13, 2009 | 08:44 AM
shanes66charger's Avatar
shanes66charger
about 5k. All that will really happen if you over rev is you'll bend the pushrods and float out the valves.
put in new pushrods in a few minutes and hit the key again.
if you got bad bearings/it's gonna go eventually anyways.
