Fuel pump problem
Old May 9, 2009 | 11:38 PM
MuddyAxles II's Avatar
MuddyAxles II
Fuel pump problem
Dad has a 2006 E-350 Quigley w/ 43,000. Last winter he had a problem that ended up being a bad fuel pump..."sock" got plugged they said, maybe by rust from the "Quigley-ized" tank seam. Not covered by warranty, of course. That extended warranty they bragged up was powertrain only.
Anyhow, folks went on vaca and about halfway through their trip the fuel pump started going bad again; only had 3,000 miles on it. This thing is $415 a pop, plus tax, and whatever else.
Anyone else heard of any particular problems with van fuel pumps going bad prematurely?
Thanks.
Old May 14, 2009 | 04:18 PM
MuddyAxles II
Posted in fuel section
No response here so I posted this in greater depth in fuel section.
Old May 15, 2009 | 06:39 PM
abn's Avatar
abn
Did you replace the actual fuel filter as well as the sock filter? From what I've read on the interweb clogged fuel filters make the pump work hard and are a leading cause of premature failure.
Old May 16, 2009 | 02:59 PM
MuddyAxles II
I wasn't there
But was told that entire fuel pump, sock and all was replaced a $415.00 part).
Fuel filter was clean and free running.
pbjosh
Sep 7, 2016 02:46 PM
Redinwolfe
30
Jun 5, 2016 07:54 PM
davelength
Vehicles for Sale
Aug 8, 2015 04:37 PM
mtnxtreme800
16
Aug 28, 2011 07:17 AM
SuperDutyKing
Mar 11, 2010 07:30 PM
