distribution bock help please
Old May 9, 2009 | 09:38 PM
chopped&dropped's Avatar
chopped&dropped
ok today i got all my parts brake booster master cylinder new brake lines and distribution block
my question is that i got a distribution block but it was mounted on the power steering pump instead of the frame i looked at other trucks with it on the frame and it looked very close to the one mounted on the pump so would these blocks be the same and can some one tell me wat all 5 lines go to
is it 2 from the master cylinder
2 to the front brakes
and 1 to the rear
and if so which one goes where and do i need the coiled brake lines ?
Old May 9, 2009 | 10:14 PM
montana_highboy's Avatar
montana_highboy
Coiled brake lines are to compensate for suspension travel, you need to address this issue when you lift, as you are lowering it shouldn't be a concern.
