Modular V10 (6.8l)
help for a rookie
Old May 9, 2009 | 09:31 AM
The Mim's Avatar
The Mim
help for a rookie
ok. so i just looked at manifold and i notices that on each side i only have 3 good bolts and 2 are broken on each side. how bad is this? can i drive around for a while like this or is it something that i should fix soon?
Old May 9, 2009 | 10:09 AM
BareBones's Avatar
BareBones
Just to give you a quick response, this is a common problem without disasterous consequences. You'll have plenty of time to work the issue.
Old May 9, 2009 | 12:05 PM
The Mim's Avatar
The Mim
ok thanks for the help.
Old May 10, 2009 | 09:45 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Although, if it starts leaking, the carbon monoxide in the cab is NOT a good thing.
Old May 17, 2009 | 04:59 PM
hydro_37's Avatar
hydro_37
And it will only get worse in time.
