pulling the steering wheel
Old May 8, 2009 | 08:51 PM
4x4 stepside's Avatar
4x4 stepside
heres the deal I bought a used 95 f150 man trans tilt steering you can move the steering wheel up and down and side to side I started to pull the steering wheel and found the one of the 5/16 bolt holes for the puller has stiped out threads any ideas how I can pull the wheel do I drill and retap or what thanks
Old May 8, 2009 | 09:07 PM
subford's Avatar
subford
I found that on a 94 van the other day, yes I retap it and it pulled off OK.
Old May 8, 2009 | 09:57 PM
4x4 stepside
what size tap did u use
Old May 8, 2009 | 10:04 PM
subford's Avatar
subford
I think it was a 3/8 but do not remember if I used NC or NF.
Old May 8, 2009 | 11:02 PM
1966Tbird's Avatar
1966Tbird
you could helicoil it
Old May 9, 2009 | 07:18 PM
4x4 stepside
thanks hopefully I can get back into it this week
Old May 12, 2009 | 06:32 PM
4x4 stepside
ok drilled and taped the holes and the wheel came right off now the clock spring it says to check the service manual before removing I know they are easy to messup anyone got a link on the removal procedure thanks
Old May 12, 2009 | 09:42 PM
subford's Avatar
subford
Removal
1. WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR SYSTEM DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY AND BACKUP POWER SUPPLY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE POSITIVE BATTERY CABLE MUST BE DISCONNECTED FOR ONE MINUTE PRIOR TO SERVICING OR REPLACING ANY SYSTEM COMPONENTS.
Disconnect battery positive cable and wait one minute for backup power supply energy to be depleted.
2. Remove four nut and washer assemblies retaining driver side air bag module to steering wheel (3600).
3. Disconnect the electrical connector on driver side air bag module from connector on air bag sliding contact (14A664).
4. WARNING: AFTER REMOVAL, PLACE AIR BAG MODULE ON BENCH WITH TRIM COVER FACING UP.
Remove driver side air bag module.
Installation
1. Fill out the traceability postcard supplied with the new driver side air bag module and return it to Ford Motor Company. Note the diagnostic trouble code.
2. Connect wiring connector of the driver side air bag module to connector on the air bag sliding contact.
3. Position driver side air bag module to steering wheel and secure with four nut and washer assemblies. Tighten to 4-6 N-m (35-53 lb-in).
4. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
5. Connect battery positive cable.
6. Prove-out system.
Old May 15, 2009 | 02:43 PM
4x4 stepside
got the wheel off and changed the bearings in the collum and put in a new ignition cyl while I was there. before I put every thing back I tried to start the truck it would crank but wouldn't start WHAT THE!!!!!!!!!! so I checked all the connections then I seen a plug hanging near the light switch it had been pluged into a blank spot in the inst. cover next to the light switch so I pluged that back in and the truck started so WHAT IS THAT THING AND WHY DOES IT CONTROL MY TRUCK from the front it looks like a blank hole also how do you get the spring compressed and back in for the tilt wheel
Old May 15, 2009 | 05:30 PM
subford's Avatar
subford
That is a fuel pump and fuel gauge jumper.
If you had two tanks the selector switch would be there.
Old May 15, 2009 | 05:48 PM
4x4 stepside
thats what I thought it must be scared the crap out of me when the truck wouldn't start any idea on getting the tilt spring back in
PinkyRingz
Jan 4, 2020 12:42 PM
scsi6
Jan 14, 2016 11:14 AM
trilogymac
Nov 2, 2013 02:00 PM
Big Ruth
Nov 8, 2012 08:46 PM
Palomino
1997 - 2003 F150
Jan 2, 2008 09:26 PM
