Lift pump issues
Old May 8, 2009 | 08:32 PM
TourqueRise's Avatar
TourqueRise
Lift pump issues
I just installed a lift pump yesterday (mechanical). It was a bent arm one, and was installed in the low cam position. After installing it the truck became quieter, and sounded like the timing got retarded. Did the new pump fail? Do new pumps retard timing from old ones. The pump also looks like its leaking, but not from the inlet, outlet, or the vent holes. Thanks.
Old May 8, 2009 | 08:43 PM
rupejosh's Avatar
rupejosh
you could be leaking internal if you blew the diaphram.i would have just done an electric pump
Old May 9, 2009 | 12:06 AM
LCAM-01XA's Avatar
LCAM-01XA
lift pumps do not affect timing, unless there is a huge difference in pressure between your old unit and the new one. If the pump is leaking there is a problem with it, bring it in and get a new one.
Old May 9, 2009 | 12:20 AM
Dean88's Avatar
Dean88
you didnt' get the one from vatozone did you?? I put one of there's on my truck and after running for about 45 seconds it died.
Old May 9, 2009 | 12:22 AM
TourqueRise
The pump is a carter. It was 60 bucks.
Old May 9, 2009 | 01:06 AM
1994diesel's Avatar
1994diesel
hmm, i bought a carter lift pump a while ago that was $45(bent arm kind). It went out a month ago, it was leaking and not pushing enough pressure, and i got it replaced under warranty. It seems like carter has let go of there quality control.
