95 aode shift concerns
Old May 8, 2009 | 04:30 PM
TECH159's Avatar
TECH159
Thanks in advance,im new to site.worked for ford until 91 . This trans. Has early shifts,no codes ,74,000 miles for the last 5 years customer has driven in 3rd gear because of this issue i rebuilt unit knowing probably would not fix issue.only 1-2 accum.spring broken no burnt parts,replaced convertor.is the pcm in line for reflash per tsb 97-9-8 or replace? Been a while since 91 lost alot of info and hair ect.any help would be greatly appreaciated,thanks!
Old May 13, 2009 | 08:22 AM
TECH159's Avatar
TECH159
update after 2 test drives all is well, great shifts , and performance . need to slow down the pace some times and smell the roses.
