Need help on wiring!
Old May 8, 2009 | 03:51 PM
CoalDust's Avatar
CoalDust
I have an 87 f150. The truck come to life as a 4.9 v6 EFI, 5 speed 4x4, now the truck is a 390 carb, auto 4x4. The guy who I got the truck from done a poor job on the swap on the truck, theres taped up wires every were and all the wires for the EFI is still there. I want to fix the wiring the right way and get rid of all the wires that I dont need. Ive never really done this before.
1.I have the haynes repair manual but I cant make sence out of the diagram. Is there any better wiring diagram out there?
2.There are to "plugs' under the hood a round one and a long flat one. Do I need any of the wires for the flat one that plug into the CPU?
3. Any one ever use a painless wiring harness? How would it work in my truck? could I see use the radio and inside cab lights?
Any help would be helpful.....thanks
Old May 8, 2009 | 03:57 PM
nobody420666's Avatar
nobody420666
well the old wiring for the efi is useless for the carb its for the wrong engine and none of the wires well connect to the 390 so i would say just pull the old harness out and throw it away or sell it thast about all i can help u out on that
Old May 10, 2009 | 07:14 PM
CoalDust's Avatar
CoalDust
Any body know were I can get wiring diagrams out there? I need help with this in a bad way
Old May 10, 2009 | 10:04 PM
redbayredneck's Avatar
redbayredneck
wiring problems too
I'm about to have to redo my wiring on my 1987 Ford too, it still has the stock 302 in it though. The previous owner did some "home-grown" re-wiring in it. Any wiring diagrams would be great.
Old May 11, 2009 | 08:03 AM
subford's Avatar
subford
Not sure what diagram you want.
Do you need one for something with a 390 in it from about 1966 or are you looking for a 1987 FI truck wiring diagram?
Old May 11, 2009 | 08:05 AM
subford's Avatar
subford
What system are you wanting a diagram for?
I may be able to come up with a 1986 or 1988 but have nothing for 1987.
Old May 11, 2009 | 09:23 PM
CoalDust's Avatar
CoalDust
Anything will help. Thanks
Old May 12, 2009 | 07:48 PM
CoalDust's Avatar
CoalDust
Im goona brake it down into parts..........how do I need to hook up my voltage reg. soleniod,and ignition? Any one know what color wires run to my ignition? Also on the flat long plug on the fire wall is that all for the engine? Is it just engine or is it lights too? If its just engine controlls I can just get rid of it. Any body have the ford mannul of the wiring? thanks
Old May 12, 2009 | 09:52 PM
subford's Avatar
subford
The EEC long plug is for the engine only.
Did the 390 come with ires on the engine for the Ignition system?
What Ignition system are you going to run (points, DS II)?
DP II:
http://i54.photobucket.com/albums/g9...itionDP283.gif
http://i54.photobucket.com/albums/g9...parkwiring.gif
1986 TFI Ignition:
http://i54.photobucket.com/albums/g9...ld/1986TFI.gif
Old May 13, 2009 | 08:44 PM
1966Tbird's Avatar
1966Tbird
man i wish i could swap my 700hp 390 into my truck that would be one wild ride i LOVE FE's they are imho the best engine ford ever made
