Cranking longer
Old May 8, 2009 | 03:11 PM
yachtonwheels's Avatar
yachtonwheels
Cranking longer
I bought a 2000 7.3 powerstroke with 220,000 miles on it in march. So far it's been running great and I've had very few issues with it. I've noticed recently thought that it's starting to crank longer before it fires. Once it does fire it runs fine and everything is smooth. I recently changed the oil and it was doing it both before and after the oil change. I want to say it takes between 5-10 seconds to start, whereas when I first got the truck it took maybe 3 even on a cold day. Is there something to look into or am I just being a picky ****?
Old May 8, 2009 | 03:19 PM
Excursion4X4's Avatar
Excursion4X4
Every time you start it, or just on the first time for the day?
Welcome to FTE!!
Old May 8, 2009 | 03:21 PM
yachtonwheels
Pretty much every time I start it
Old May 8, 2009 | 04:18 PM
bigsteve1969's Avatar
bigsteve1969
mine takes awhile to start as well... as long as it starts i dont care
Old May 8, 2009 | 05:07 PM
1996pwrstrk's Avatar
1996pwrstrk
Start with cleaning your battery terminals ,check and clean connection at starter ,if no change (make sure that you have the correct size batteries )have the batteries load tested make sure that they are tested separately or you will get a false reading if one is bad you need to replace them both. If batteries are good pull the starter and have it tested.
Old May 8, 2009 | 05:13 PM
ron's power stroke's Avatar
ron's power stroke
any smoke when she fires??? could be injector oring going bad..and draining the reservoir a tad..
