valve cover question
Old May 8, 2009 | 08:15 AM
bigrig62's Avatar
bigrig62
Can anyone tell me if the uvch is included when you buy the valve cover gaskets. For the price they should be 60.00 each
Old May 8, 2009 | 08:19 AM
clux's Avatar
clux
Nope, the wiring harness is a separate item. Probably another $50 each.
Old May 8, 2009 | 09:25 AM
SuperDoodie's Avatar
SuperDoodie
Yep they are separate. Often times you can re-use one or the other.
Old May 8, 2009 | 02:50 PM
4inchlovin's Avatar
4inchlovin
The reason they are 60 a piece is because they power connects through them.... But ya as they said the harness is a separate piece. If you doubt the condition of yours at all DO NOT re-use them... In the past month i can think of at least 3 threads that ended up being because of people re-using gaskets...
