01 Supercrew
Old May 7, 2009 | 08:16 PM
caveman524's Avatar
caveman524
01 Supercrew
I have a 2001 Supercrew and am in a position where I need a traveltrailer to live in and am wondering if I need to get a bigger truck or if I can haul a 26 foot 5th wheel that weighs 5K lb. I wouldnt be pulling it everyday, just about 200 miles to start with then I will be able to get a bigger truck.
Just really wondering if it would handle the hitch and trailer.
Thanks Lee
Old May 8, 2009 | 06:56 AM
hanklin's Avatar
hanklin
I have the same setup and it works just fine. Why bigger? 5k is like getting groceries
Old May 8, 2009 | 09:12 AM
senix's Avatar
senix
you can do it fine with the supercrew. Do get a trailer brake controller though so you can use those trailer brakes. Do you have a reciever on the truck? 5K is a little much for the bumper.
Old May 8, 2009 | 09:35 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I doubt if he's gonna hook a 5th wheel to the bumper.....LOL
Old May 8, 2009 | 09:48 AM
senix's Avatar
senix
Well I messed that one up didn't I!
Old May 8, 2009 | 03:54 PM
grafekie's Avatar
grafekie
A fifth wheel in a super short bed will be trouble... make sure you have angles and dimentions planned out and make sure it all fits. A regular short bed is on the small side for a fifthwheel (its okay for a gooseneck and the expensive sliding fifthwheels), and a SuperCrew bed is even shorter than a short bed.
Old May 9, 2009 | 04:17 PM
hanklin's Avatar
hanklin
How is a sc. short bed smaller than a short bed ? I havn`t had any problems turning tight or otherwise
Old May 9, 2009 | 04:41 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Try making a tight turn with a 5th wheel with the pin of the trailer built up under the overhang and you'll clip your truck cab with it.....vs the pin build into the trailer where it hangs out in FRONT of the trailer. Even with it there, in a short shortbed,, it'll hit the cab in a jackknifed turn.
Old May 9, 2009 | 06:25 PM
grafekie's Avatar
grafekie
A standard short bed truck is 6'4"... a crew cab short bed is between 5' and 6', shorter than a normal short bed. A full bed is recommended for trouble free fifthwheel towing, and is 8'.
You won't notice a difference in regular driving... the whole point of the shorter-than-short-bed size is to keep the wheelbase the same size so you DON'T notice. But when towing with an in-bed hitch, clearance with the cab is very important. A gooseneck doesn't have quite as big of a problem due to the trailer design (most are narrower and more pointed than fifthwheel campers) and can handle a short bed easily. But fifthwheels need special equipment to make sure you don't crush the cab in tight turns.
Old May 10, 2009 | 08:29 AM
hanklin's Avatar
hanklin
Hold on, this was about supercab, on your (nathan) last post you bring up crew cab.I just went out an measured my bed to make sure I don`t speak out of turn and it is 6`10. I have jack-knifed in both directions and did not hit my cab. I`m confused here. How big is your bed in the f150?
Old May 10, 2009 | 11:34 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Hank, can you post a pic of your truck/trailer hitched up? Thanks.
Old May 10, 2009 | 12:05 PM
hanklin's Avatar
hanklin
Nah, my digital camera is to old, Ihaven`t bought a new one yet,soon
Old May 10, 2009 | 01:52 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
..any digital will work.....
Old May 10, 2009 | 04:06 PM
jsimon724's Avatar
jsimon724
You're talking about a supercab (extended cab). The OP was talikng Supercrew (a crew cab F150 with about a 5' bed). There are slider hitches for 5th wheels that may help in his situation. would probably be best to take it to a dealer and have them check it out. Also, if it's a newer model trailer, some have front caps that are designed to help avoid damage with short-bed trucks (Cougar is one manufacturer with such models.)
Old May 10, 2009 | 11:45 PM
grafekie's Avatar
grafekie
Hankin, what Jim said... the OP is talking a Super Crew F150, which has a very short bed. Too short for a fifthwheel, from what people tell me. Probably too short for a gooseneck too. If you want a fifthwheel it is recommended to get a full 8' bed, or a 6'4" bed with a slider fifthwheel or a standard gooseneck, or a tagalong trailer with anything smaller.
