Sponsored by: Real Truck
What Fluid
Old May 7, 2009 | 02:58 PM
mravetto's Avatar
mravetto
What Fluid
OK I got my trans back from the shop yesterday and need to put fluid in it but Ford could not tell me how much was needed and was not sure of what type to use. Was hoping someone could help me out I have a pre march 99 F250 with the ZF 6speed Manual, anything will be helpful, Thank You
Old May 7, 2009 | 03:17 PM
DAVE67FD's Avatar
DAVE67FD
I believe the correct fluid is ATF rated MERCON V but someone else may correct me. Not sure of the quanitiy. If you have a owners manual it will list type/amount.
Old May 7, 2009 | 03:25 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
The fluid to use is mercon/dexron III. You will need approximately 6 quarts to fill the transmission. Dan.
Old May 7, 2009 | 03:31 PM
mravetto's Avatar
mravetto
can I use Ams Oil, Royal Purple, or add some Lucas to the Mercon ?
Old May 7, 2009 | 04:02 PM
DAVE67FD's Avatar
DAVE67FD
There is always a debate on what is the correct or optional fluid you can use. Many use the synthetic mobil1/amesol/ etc..
Here is Fords TSB
http://www.fcsdchemicalsandlubricant.../tsb/06261.pdf
