This is in reference to my last post, "High voltage Injector question" After a couple hours chasing an aparrently false DTC P1294, I decided to check the ICP voltage and found that it ws very low, checked the IPR coil windings and found that they were open, replaced the IPR coil only, the truck fired right up and ran great! Thank You Bdrummonds for steering me in the right direction!
Glad it was an easy fix.
If you don't mind me asking what did you pay for IPR solenoid coil?
My employer buys and sells quite a few Ford SD's (also owns an auto salvage business) and some end up as parts vehicles, so my IPR coil was used. Sorry I couldn't be more help
Mike, Glad I could help. Stick around and jump in on a few threads. I am sure with your knowledge you could contribute greatly to our little slice of the world.
