Automatic Transmission Modulator Valves
Old Sep 5, 2002 | 07:53 PM
turbosek2's Avatar
turbosek2
I have a 67 F250 with a Cruise-o-matic tranny. When cold it sticks from 2 to 3 and when I put in reverse the truck drops like it is engaging, but whe I let off the brake it does not roll out of my driveway. If I give it gas, it revs then engages in peel-out mode (posi). The only way I can eliminate this in reverse is to hold the brake on while I rev it a few times, then is idles down out of my drive way and does not peel out.
Would replacing the modulator valve solve this? Can I just swap out the old for the new, or will I need to do a bunch of other stuff too? Thanks
Old Sep 5, 2002 | 11:19 PM
Brian460's Avatar
Brian460
The modulator won't have any effect on the reverse problem, but it might fix the 2-3 upshift. Not to sound like a dummy, but that is a the way a tranny will act when it is low on fluid.:-)
Old Sep 5, 2002 | 11:35 PM
turbosek2's Avatar
turbosek2
Thanks
Old Sep 6, 2002 | 12:24 AM
drumguy's Avatar
drumguy
kendogg
Nov 22, 2023 05:07 AM
swhitney133
Nov 11, 2016 07:15 AM
EyesOffMyLongBed
Paint & Bodywork
Jul 3, 2014 07:47 AM
dirty fingernail
May 6, 2011 01:40 PM
rjd75
Nov 27, 2005 03:06 PM
