Engine Codes?
Old Sep 5, 2002 | 07:02 PM
91paint pealer's Avatar
91paint pealer
Engine Codes?
Hey everyone. Is it possible for the transmission to cause the check engine light to come on? The local mechanic said i had a code for the torque rotor clutch. Is he really right, or do i need to find another mechanic? I have a 91 F-150 300/6 AOD 200,000 and still rollin. (unless the tranny blows!)
Old Sep 5, 2002 | 07:52 PM
86F150TRUCKDUDE's Avatar
86F150TRUCKDUDE
Engine Codes?
If you got 200k out of that AOD consider yourself lucky.
Old Sep 6, 2002 | 09:30 AM
mrshorty's Avatar
mrshorty
Engine Codes?
Did he give you the code number? From what I've seen, a transmission code is more likely an indication of a bad electrical connection between the transmission and the computer than a problem in the transmission. See if you can get the actual code number, and maybe we can help you a little more. (If you can't get the mechanic to give you the number or he's forgotten, you can get it yourself using the procedures described in http://www.dalidesign.com/hbook/eectest.html)
Old Sep 6, 2002 | 10:58 AM
jim henderson's Avatar
jim henderson
Engine Codes?
