Sponsored by: Auxito
Maybe Tansmission Problem?
Old May 6, 2009 | 01:31 PM
DuckMendenhall's Avatar
DuckMendenhall
Afternoon...
Need some help!! I own a 2000, F-150/5.4L, 4X4 styleside...as anyone around my area can recall, last week we got engulfed with 11" of rain. Leaving for work last Tuesday, I ran through mid-to-lower hub water. Got through it just fine, check engine light came on, and then went off when driving home that afternoon.
now...I am having shifting problems from idle to 50-60 mph, no noise, but rough riding. Thought it was the gas, ran it empty filled up this morning, same thing.
Problems are...low gas mileage, rough riding, rough idle, hesitant at stop sign. Rough riding increases when A/C running, power wise. Any help would be greatly appreciated. Thanks in advance.
Lee
Old May 7, 2009 | 01:15 AM
JJ98's Avatar
JJ98
check and see if water got it the engine bulk head cable the one with a 10 mm bolt head buy the battery u should see the ecu commind out of the fire wall also maybe some watersplashed into the spark plug boots or the coil packs good luck
Old May 7, 2009 | 02:22 AM
phil6608's Avatar
phil6608
Id say you got a wet or bad COP.
Old May 7, 2009 | 07:15 AM
DuckMendenhall
Thank you again. The gentlemen I spoke to yesterday, stated that it probably is coil packs. I am getting a tune up on it as well, it has 196K, I need it to last a little while longer.
Old May 7, 2009 | 11:42 AM
phil6608's Avatar
phil6608
This might save you some money.
eBay Motors: 8 NEW IGNITION COILS coil 1997-2005 FORD F150 V8 DG508 (item 360141569403 end time May-22-09 14:35:44 PDT)
